KeyserSoze6
Jun 13, 2023Tutor
My home is extensively automated
I share your frustration with the 960, I am an early adopter, bought the unit when it first came out. My home is extensively automated with WiFi wall switches, plugs and numerous other devices runnin...
KeyserSoze6
Jun 14, 2023Tutor
Current firmware as of 6/14/23.
Spectrum internet (current speed 580mbps) modem model #E31T2V1, docsis 3.1
cables are all 6E or better. (Currently utilizing 2.5ghz Ethernet for most of the wired portion of the network.
81 devices connected to WiFi network most on the IoT network.
‘’WiFi analyzer shows other networks but not what I would consider congested, channels are set to auto.
The configuration file seems to become corrupted and/or unstable every 30-90 days with the reload from backup fixing the stability/dropping issue most of the time.
Jun 14, 2023Guru - Experienced User
What do you mean by "The configuration file seems to become corrupted and/or unstable every 30-90 days"
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
Are the RBS wireless or ethernet connected?
How many devices do you have connected in total?
Are you using the IoT SSID network for some of your devices?
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Please confirm CAT# LAN cable. There is no CAT6E. There is CAT5E. CAT6A STP is recommended between the RBR and ISP modem.
- KeyserSoze6Jun 14, 2023Tutor
Yes, Cat 6 not E. I realize you’re trying to help, but people are not (generally) having problems with the wired portion of the router/networks. From what I can tell from the forums is the 960’s WiFi stability issues. For what it’s worth, my house is 2k sgft. I bought this router because I was pushing 100 WiFi devices and specs on the router say 200, so I’m not pushing the unit beyond its designed limits.
I still believe, based on my experience, the firmware is not sufficiently stable. The hardware design is stellar, firmware not so much. If this was a $100 cheapo setup then you get what you pay for but it’s not. Netgear markets this as the pinnacle of mesh router technology and charges a premium price to go along with the marketing hype. For many end users, dare I say “Power Users”, because who else would pay $1,500 for a consumer router, the user experience is wildly inconsistent. This just isn’t a mature product and we deserve better.
- FURRYe38Jun 14, 2023Guru - Experienced User
So we need you to please give feedback to the questions presented so we can better help you out. Makes it hard for us to help you troubleshoot and solve issues with out details and information. We are here to help and see if we can resolve problems only.
FYI, for a 2000sq ft home. the RBR would only be needed. Maybe one RBS placed at 30feet or more and the power on the RBR turned down to 25%. That size of home and having two RBS place would be too much wifi and maybe the cause of what your seeing. Too Much Wifi: https://youtu.be/UR0viMLISz4
I have a 5000sq ft home and run two RBS and power is at 50-25%. However I don't have same device count either. No issues seen over long periods of time.
Yep. Having ANY MESH system in a small size home is going to be problematic with having too much wifi signals running around. Like a busy noise restaurant as an example. Kind of hard to hear who your taking to with all the background noises happening. I presume that for the average home user, may not fully understand that and thats ok. Were here to help where we can to get users to understand that if possible.
Why we need the details and feedback to questions presented. This helps us and gives us direction.
Yes not everyone is having problems with MESH systems.
Lets see if we can get the details now.
