bassvic
Jul 18, 2022Aspirant
My iPhone 13 pro would loss the internet connection
My RBK752 and one additional RBS750 satellite system has the same issue. My iPhone 13 pro would loss the internet connection or wifi connection occasionlly after walking through/between the satellite...
Jul 18, 2022Guru - Experienced User
How many RBS doe you have deployed?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What CTS value are you using currently? Try 500 or 2347?
bassvic
Firmwire: 4.6.8.5
The orbi ax system is connected to Taiwan CHT modem/ONT model RTF8217, via PPPoE
The system include one RBR750 and two RBS750, using wired backhaul
My home: Three floors, each floor 18.2 sq ft.
The router is located on second floor and the satellites located on first and third floor.
Channel: 2.4G: auto / 5G: 48
I have tried to set the 2.4G power to 50% and CTS/RTS value to 2347 but the issue persists.
- FURRYe38Jul 18, 2022Guru - Experienced User
bassvic wrote:
Firmwire: 4.6.8.5
Are the RBS directly connected to the RBR in back or is there a patch panel or LAN switch in between?
My home: Three floors, each floor 18.2 sq ft. <18 sq ft? Thats really a small place. Can you confirm the total size of the home? ####sq ft?
Turn OFF both RBS, does the phones keep connected or do they still disconnect from the RBR?
Then turn one RBS back ON. Leave the 2nd RBS OFF. What happens here with the iphones?
Channel: 2.4G: auto / 5G: 48 <Try setting channel 11 and 48.
What iOS are you using on the iPhones?
- bassvicJul 18, 2022Aspirant
Sorry, the area of one floor is 2109.7 sq ft. (14 x 14 m^2)
iOS 15.5
The wire backhaul is connected by switches, GS108Ev3 and GS308E.
I've noticed that if I turn off one of the RBS, or set one of RBS to wireless backhaul, the system would get more stable.
Iphone in router's wifi covering area has stable wifi connecting, regardless of the RBS status (turn on/off).
Ok. For that size of home. Two RBS is too much. The RBR and one RBS and power set to 50% should work well.
The Switches could also be a problem. There maybe some protocols on this switch that could be effecting how the RBS are communicating and passing traffic back and forth. There any web page for these switches by chance? I have same models, just not the E version. Mine are the unmanaged version of what you have.
What CAT# lan cable are you using between the RBR, RBS and Switches?
