scamperpamela
Jul 29, 2021Star
My new Orbi RBR850 mysteriously dropped some internet connections
I installed an RBR850 and 3 satellites last weekend. I have about 30 devices attached - Rokus, phones, computers, Ring security cameras, robot, etc. All have been working well. Suddenly tonight a l...
michaelkenward
Jul 30, 2021Guru - Experienced User
scamperpamela wrote:
Suddenly tonight a large block of devices could no longer connect to the internet.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
scamperpamela
Jul 30, 2021Star
Firmware is 32.18.1_1.4.14
Modem (from Spectrum) is Arris TM1602. Does not include a router. No extra ports.
Thank you for your help!
- michaelkenwardJul 30, 2021Guru - Experienced User
That's good. Needed to rule that out.
A modem/router crops up far too often in these problems.
