32Chop
Sep 17, 2020Aspirant
My Orbi AX 6000 won't connect to google home
My AX6000 won't connect to my google home. I have the OrbiAX6000 .
ekhalil
Sep 18, 2020Master
32Chop wrote:My AX6000 won't connect to my google home. I have the OrbiAX6000 .
I have almost all types of Google Home devices connected to my Orbi RBK852 with no issue:
- 2 x Google Home
- 3 x Google Home Mini
- 1 x Google Nest Mini
- 3 x Google Nest Hub
Most of the time i see those devices connected to the 5GHz band. I have AX enabled.
- What modem/router do you have between Orbi and your ISP? Please check for double NAT.
- On the Google Home devices, please disable "Let others control your cast media" since this will make the each device broadcast it's own SSID which can cause much interference if you have many Google Home devices. I noticed that this can cause other devices at home not to work properly.
