Winkh
May 13, 2022Aspirant
My Orbi mobile devices cannot find orbi
The internet is working fine but I cannot get satellites seen
- May 21, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 13, 2022Guru - Experienced User
What Orbi do you have?
What FW is loaded?
What mobile devices do you have?
Jeffgear
May 14, 2022Virtuoso
Have the satellites ever worked or is this a new setup, if it is new then try setting up the satellites near the router and then relocate them? They may be too far from the RBR to sync.
- WinkhMay 21, 2022AspirantThanks. I needed to reset the system. Fairly simple to do. All satellites are communicating as before.
- FURRYe38May 21, 2022Guru - Experienced User
Enjoy. 📡
