Winkh
May 13, 2022Aspirant
My Orbi mobile devices cannot find orbi
The internet is working fine but I cannot get satellites seen
- May 21, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jeffgear
May 14, 2022Virtuoso
Have the satellites ever worked or is this a new setup, if it is new then try setting up the satellites near the router and then relocate them? They may be too far from the RBR to sync.
Winkh
May 21, 2022Aspirant
Thanks. I needed to reset the system. Fairly simple to do. All satellites are communicating as before.
- FURRYe38May 21, 2022Guru - Experienced User
Enjoy. 📡
