titaniumrx8
Sep 29, 2021Apprentice
My Orbi RBK753S Has Been Stable Under V4.6.3.16_2.0.51 For 2 Weeks
I'll try to be brief. When the first 4.x update was pushed onto my mesh, it was immediately destabilized after 3 months of smooth operation. I immediately opened a case with support. I have had 2 sup...
Oct 06, 2021Guru - Experienced User
How was your system updated? Auto Update or Manually Updated yourself?
Mr410
Oct 06, 2021Star
FURRYe38 wrote:How was your system updated? Auto Update or Manually Updated yourself?
Autoupdated. I'm a don't rock the boat kind of guy when it comes to networking. A day after the latest firmware update several weeks back, it appeared that my WAN connection was down, even tho wifi appeared to be up, just no Internet. It happened same time for two straight days. I assumed that it might be due to the DHCP lease of 1440 minutes. The reboots worked, but I went ahead and set a static IP on my Fios router for the Orbi and then on the Orbi set the wan port to static. Not one drop, outage or slowdown in two weeks. Solid performance inside and outside the 3000sq ft house, using just the router and satellite. Like I said, not rocking the boat and it appears to work very well.
- FURRYe38Oct 06, 2021Guru - Experienced User
IF you have a router infront of the RBR, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option#2 for your configuration.
I also recommend a full power OFF of the host router, RBR and RBS for 5 minutes, then back ON with the ISP modem, RBR then RBS.
