titaniumrx8
Sep 29, 2021Apprentice
My Orbi RBK753S Has Been Stable Under V4.6.3.16_2.0.51 For 2 Weeks
I'll try to be brief. When the first 4.x update was pushed onto my mesh, it was immediately destabilized after 3 months of smooth operation. I immediately opened a case with support. I have had 2 sup...
codejanitor
Oct 05, 2021Star
I bought a used RBK752 from eBay. The older firmware 4.6.3.7 came installed and had a disconnect so I disabled AX feature and it worked fine since then.
When the 4.6.3.16 beta came out I manually installed it and turned on AX. No issues ever since.
Oct 05, 2021Guru - Experienced User
Kewl. Did you power OFF the RBR and RBS for 5 minutes then back ON after the FW was updated? Something I recommend after any FW updates.
- codejanitorOct 05, 2021StarYep I did.
- FURRYe38Oct 06, 2021Guru - Experienced User
đ
- FURRYe38Oct 08, 2021Guru - Experienced User
Anyone Interested? https://community.netgear.com/t5/Orbi-WiFi-6/New-RBR750-RBS750-Firmware-Version-4-6-5-14-Released/m-p/2148731/highlight/true#M21331
