chapotito
May 13, 2023Aspirant
My Orbi RBR750 runs at half half speed.
For some reason, my RBR750 is running at half speed. I am supposed to be getting 200 Mbps. When I connect the PC directly to the modem, I get 200+, when i connect the Orbi i get from 85 to 95, neve...
- May 16, 2023
Well, problem fixed. Change all the cables just in case it was the cables. . But I had to reset the Orbi to factory settings. I didn't want to reset the thing to original factory settings because there are a lot of things on wireless, not counting having to reset the three satellites. But that did it. I am back to 230 Mbps. Now I have to reset the satellites and reconnect the 5 security cameras, the thermostat, the 3 echos, two TVs, PS5, PS4 and i am pretty sure I am forgetting two or three other things that I dont remember. I hate it, but at least I am up to speed.
I rechecked and I am abou5t 90% sure the speed dropped right after I updated to the last firmware about three months ago.
May 14, 2023Guru - Experienced User
You can check and see if its connecting at gigabit speeds.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
