chapotito
May 13, 2023Aspirant
My Orbi RBR750 runs at half half speed.
For some reason, my RBR750 is running at half speed. I am supposed to be getting 200 Mbps. When I connect the PC directly to the modem, I get 200+, when i connect the Orbi i get from 85 to 95, neve...
- May 16, 2023
Well, problem fixed. Change all the cables just in case it was the cables. . But I had to reset the Orbi to factory settings. I didn't want to reset the thing to original factory settings because there are a lot of things on wireless, not counting having to reset the three satellites. But that did it. I am back to 230 Mbps. Now I have to reset the satellites and reconnect the 5 security cameras, the thermostat, the 3 echos, two TVs, PS5, PS4 and i am pretty sure I am forgetting two or three other things that I dont remember. I hate it, but at least I am up to speed.
I rechecked and I am abou5t 90% sure the speed dropped right after I updated to the last firmware about three months ago.
CrimpOn
May 15, 2023Guru - Experienced User
chapotito wrote:
The LAN cable is a CAT6.
Please describe more about how speed is being measured:
- Using a Speed Test run on the PC when it is connected to the router or to the XB-7?
- The Cat6 cable connecting the PC to the Orbi is disconnected from the Orbi, the Orbi is disconnected from the modem, and the cable is connected to the modem?
- i.e. only one cable is involved in the test scenarios?
plemans suggested that it would be useful to determine which speed the modem and Orbi have negotiated.
(See Wikipedia: https://en.wikipedia.org/wiki/Autonegotiation ) This is a feature built into the physical Ethernet adapter hardware for the past 20+ years. If the modem/router have negotiated a speed of 100M/Full Duplex, then is is impossible to measure a speed as high as 100Mb/sec (because of Ethernet overhead).
The primary cause of the auto negotiation failing is "something about the cable" between the modem and router.
- Perhaps one of the tiny gold wires in one of the RJ45 jacks is bent or out of alignment.
- Perhaps one of the RJ45 plugs is not crimped entirely correctly.
- Perhaps the cable has been strained or crimped at some point.
- Perhaps one of the plugs is not seating correctly (the tiny 'snap thingy' is worn or loose).
The most obvious trouble-shooting step is to swap out the cable between modem and router with a new cable.
chapotito
May 15, 2023Aspirant
Speed Test cable connected directly to the XB-7 = 200+
Speed test same cable connected to the Orbi = 50 to 85.
Multiple cables. All CAT6.
WAN reads 1000M/Full Duplex
