cdysthe
Mar 17, 2022Virtuoso
My Orbi RBR752 drops IPv6 every hour or so.
I have had my Orbi RBR752 (with the latest firmware) set up with IPv6 for a year on a Xfinity gigabit connection through a Netgear CM2000 modem. A few days ago I was changing the DNS settings for IPv...
Mar 17, 2022Guru - Experienced User
what firmware version are you on?
I'm using a RBK752 on xfinity with ipv6 enabled. (I switch routers a lot)
- cdystheMar 17, 2022Virtuoso
Firmware is latest as far as I know: V4.6.5.14_2.0.54
I have had IPv6 enabled and working on this firmware until a few days ago when it now drops after an hour. I have to go in and disable/enable it again and it works for another hour or so. So this is a new problem. I have not made any changed to my system, same router/satellite/modem/connection. Maybe I have to factory reset? Restart the modem? I can't figure this out.
- plemansMar 17, 2022Guru - Experienced User
You can try factory resetting the router/modem if you'd like.
It could just be a xfinity issue.It shouldn't impact much services if ipv6 is disabled.
It comes disabled from default and many don't even enabled.
- cdystheMar 20, 2022VirtuosoI have found that many have this IPv6 issue with Orbi systems on Comcast/Xfinity connections. Have a look here:
https://is.gd/cecoro
I really hope Netgear will fix this through a firmware update since Comcast won't redo their vCMTS implementation which seems to be causing the problem. Until that happens I'm wasting my time trying to fix this and will keep IPv6 disabled.
- FURRYe38Mar 20, 2022Guru - Experienced User
Please confirm same thing happens on v.5:
- cdystheMar 22, 2022Virtuoso
FURRYe38 wrote:Please confirm same thing happens on v.5:
I have now run with the latest firmware 4.6.7.5_2.1.7 and the problem is partly solved. There's still issues with Auto Detect not detecting DHCP but rather 6-4Tunnel. I have to disable IPv6, then enable it again and specifically choose DCHP to get IPv6 to work as intended and like it has in the past. However, the setting now sticks and the IP has not dropped after an hour like it did on the previous firmware. That was the most serious problem. I have had working DHCP based IPv6 working for a couple of days but getting the problem with getting DHCP to work and an IP set needs to be fixed.
