cdysthe
Mar 17, 2022Virtuoso
My Orbi RBR752 drops IPv6 every hour or so.
I have had my Orbi RBR752 (with the latest firmware) set up with IPv6 for a year on a Xfinity gigabit connection through a Netgear CM2000 modem. A few days ago I was changing the DNS settings for IPv...
Mar 17, 2022Guru - Experienced User
what firmware version are you on?
I'm using a RBK752 on xfinity with ipv6 enabled. (I switch routers a lot)
cdysthe
Firmware is latest as far as I know: V4.6.5.14_2.0.54
I have had IPv6 enabled and working on this firmware until a few days ago when it now drops after an hour. I have to go in and disable/enable it again and it works for another hour or so. So this is a new problem. I have not made any changed to my system, same router/satellite/modem/connection. Maybe I have to factory reset? Restart the modem? I can't figure this out.
