cdysthe
Mar 17, 2022Virtuoso
My Orbi RBR752 drops IPv6 every hour or so.
I have had my Orbi RBR752 (with the latest firmware) set up with IPv6 for a year on a Xfinity gigabit connection through a Netgear CM2000 modem. A few days ago I was changing the DNS settings for IPv...
cdysthe
Apr 19, 2022Virtuoso
FURRYe38 wrote:Well I've let NG know about this. We'll have to wait for next FW update.
I recommend for now, either downgrade FW or use the other router has your host router and configure orbi for AP mode.
Thank you for following it up and your advice. These things are so time consuming. I have been happy with Netgear for 13 years so this was so unexpected. What makes it harder is that it may be something Xfinity/Comcast does regionally that causes it so troubleshooting could be difficult. All I can see it that the router is not happy with Xfinity's IPv6 IP assignments and cat get it set. Oh well....
Apr 19, 2022Guru - Experienced User
All you can do is make things stable for now.
- cdystheApr 24, 2022VirtuosoIt happened again yesterday by that's not why I post now. I have seen that others on other Orbi models have the exact same problem. Looks like Netgear need a general update for many Orbi models. Take a look here:
https://community.netgear.com/t5/Orbi-WiFi-6-AX-and-WiFi-6E-AXE/ipV6-disconnecting-on-Orbi-RBR850/m-p/2211433/highlight/false#M30963 - FURRYe38Apr 27, 2022Guru - Experienced User
Would be good to know if new FW changes this behavior:
- cdystheApr 27, 2022Virtuoso
I am currently on firmware 4.6.8.2
