cdysthe
Mar 17, 2022Virtuoso
My Orbi RBR752 drops IPv6 every hour or so.
I have had my Orbi RBR752 (with the latest firmware) set up with IPv6 for a year on a Xfinity gigabit connection through a Netgear CM2000 modem. A few days ago I was changing the DNS settings for IPv...
FarmerBob1
Apr 27, 2022Luminary
Did you contact Comcast/Xfinishedty and tell them about what happened and ask if there was any changes made to your service on their end that could cause that? There's only a couple of things that they could do and all but one or two would be in your favor.
But hopefully options and features in firmware updates will start rounding out across the product lines. I found in a R6700v3 that is at a neighbors that IPv6 has been going strong for over a year. And in the DeBug area there is an option to include IPv6 Stats in the DeBug Reports. And in the later versions of the FW on the RAXE500 there is a selection, "NOT TO UPDATE THE FW!"
So there's hope on the horizon . . .
CrimpOn
Apr 27, 2022Guru - Experienced User
FarmerBob1 wrote:
in the DeBug area there is an option to include IPv6 Stats in the DeBug Reports. . .
Could you post a screen shot of IPv6 stats?
I do not find an option on my ancient RBR50 debug that mentions IPv6.
- cdystheApr 27, 2022Virtuoso
All I see on the "debug.htm" page is: "Start Debug Log Capture when boot up" and "Enable LAN/WAN Packet Capture". Should I enable one or both of those and reboot?
