GandeDK
Feb 12, 2024Aspirant
My orbi rbs 850 won't connect to my rbk752 system
As far as I can see on the compatibility list these two should go together. I have been more than satisfied with my rbk752 and therefore wanted to expand it now that I needed something for a bigger ho...
Feb 12, 2024Guru - Experienced User
What FW is loaded on the 850 and 750 system.
Did you first turn OFF the 750 RBS and then try to sync the 850 RBS to the 750 RBR using the Add Satellite feature on the RBRs web page?
What happens if you ethernet connect the RBS to the back of the RBR?
