nitehawk747
Mar 16, 2023Tutor
My Orbi RKR850 Wi-Fi connection
I'm using the Orbi WIFI 6 mesh with one satellite. I just noticed that some of my WI FI connections is weak. My outside cameras, which is 20ft from the router, is connecting to the satellite, wh...
Mar 16, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
What happens if you turn down the transmit power on the RBR to 50%? Under Advanced Tab/Advanced Settings/Wireless Settings
The system is meant and designed for inside use with "some" outdoor single coverage though would be limited in range and such due to placement and building materials. What happens if you turn OFF The RBS for 1 minute then back ON? Does the camera then connect to the RBR?
