nitehawk747
Mar 16, 2023Tutor
My Orbi RKR850 Wi-Fi connection
I'm using the Orbi WIFI 6 mesh with one satellite. I just noticed that some of my WI FI connections is weak. My outside cameras, which is 20ft from the router, is connecting to the satellite, wh...
nitehawk747
Mar 27, 2023Tutor
After I powered everything down, then back up , the camera did connect to the router. Now the signal is stronger , the streaming connection better. Hey, thanks everybody for your help .
Next I'll have to learn how to limit , and setup a start and stop time to my grandson game. Thanks again.
- FURRYe38Mar 29, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
