MistaBond
Oct 18, 2023Follower
My Orbi router password no longer works (Orbi RBR850)
Hi y'all, I recently discovered that while I was setting up my Amazon Echo and tried connecting with Orbi with the correct password that came with after I bought it no longer works. I had to doub...
CrimpOn
Oct 18, 2023Guru - Experienced User
This situation appears to have two topics.... or does it?
First, connecting an Amazon Echo does not require logging into the Orbi router 'app' or the Orbi router web interface. All it requires is to select the appropriate WiFi SSID (name) and enter the WiFi password. When the system was delivered, this information was printed on the product label on the bottom of the case. Many users choose to change the WiFi credentials (although there is no requirement to do so. For the past 20 years, I have configured each new WiFi router with exactly the same WiFi credentials as the one that was being replaced. Saves me having to reconfigure my WiFi devices and also means that I can "go back" to the previous WiFi router without reconfiguring any devices.)
Thus the Amazon Echo would not seem to be relevant to the problem, correct?
When an Orbi system is delivered, the Orbi web credentials are "admin" (which cannot be changed) and "password" (which the user is forced to change to something more secure. Thus, this statement is puzzling:
It is not unusual for users to forget the router password that was entered during the initial configuration. As Forrest Gump would say, "s**t happens". If the password is rejected three times in a row, the router brings up a Password Recovery screen which wants the router serial number (from the product label) and the answer to a couple of security questions. Again, it is not unusual for users to have skipped that step when configuring the router.
When the user definitely cannot enter a password that the router accepts, the only recourse is a Factory Reset.
This does not have to be a major problem.
MistaBond wrote:
my family don't want it because they are worried if any worst-case scenario comes to their mind.
If the router is reset to Factory settings, then all that is required to keep the family happy is to configure it with exacctly the same WiFi credentials as it has now: WiFi name (SSID) and password. Everybody's devices will connect immediately and all will be good.
As far as "worst case", there could be a thunder storm and lightning could fry the router tonight.
