mbshaughnessy
Apr 18, 2022Aspirant
My Orbi Satellite issues
Hardware Version CBR750 Orbi Firmware Version V4.6.5.8_2.0.54 CM Firmware Version V1.01.08 I The system is 5 months old, the last few weeks the satellite has been having is...
- Apr 19, 2022
Hopefully with the changes and reducing the power some, should help.
mbshaughnessy
Apr 19, 2022Aspirant
Thanks, I would agree the satellite is a bit overkill -- working from and close to 30 devices, I wanted to be sure we were solid as far as our network
Apr 19, 2022Guru - Experienced User
- mbshaughnessyApr 20, 2022Aspirant
Many thanks for your guidance. After running almost 48 hours, no drops where I used to see several a day
- FURRYe38Apr 20, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
