vsoks4200
Sep 08, 2021Follower
My orbi wont connect at all
Hello, I just installed my 3 Orbi product as well as 4 additional units. The main router is hardwired to my modem. And all other 6 units a localised wihtin 300 m2. When the app starts up it asks t...
Sep 08, 2021Guru - Experienced User
What model Orbi do you have? RBK###?
- vaoks4200Sep 08, 2021AspirantThe model 850 ax
My Home is around 3300 sqm and The svarskrift distance beyween units are around 50 sqm
Apart.
Du you have any suggestions to get the system
Working ? - vaoks4200Sep 08, 2021AspirantThe manufacturer is Cisco. The service provider is a company in Denmark
- FURRYe38Sep 10, 2021Guru - Experienced User
I recommend setting up the RBR and RBS using a wired PC and web browser.
Power OFF the ISP modem and RBR for 1 minute then back ON after connecting the RBR to the ISP modem. Then walk thru the setup wizard at 192.168.1.1.
