vsoks4200
Sep 08, 2021Follower
My orbi wont connect at all
Hello, I just installed my 3 Orbi product as well as 4 additional units. The main router is hardwired to my modem. And all other 6 units a localised wihtin 300 m2. When the app starts up it asks t...
Sep 08, 2021Guru - Experienced User
What model Orbi do you have? RBK###?
vaoks4200
Sep 08, 2021Aspirant
The model 850 ax
My Home is around 3300 sqm and The svarskrift distance beyween units are around 50 sqm
Apart.
Du you have any suggestions to get the system
Working ?
Apart.
Working ?
