Orbi16
Aug 26, 2022Aspirant
My RBR750 Orbi drops certain devices
I have the same issue with my RBR750.
CrimpOn
Aug 26, 2022Guru - Experienced User
Would help to know exactly what the issue is. (see post #2 above).
Sometimes adding onto a conversation that has not progressed since August 7 (19 days ago) is not effective.
Orbi16
Aug 27, 2022Aspirant
Some devices that were previously connected to Orbi are getting disconnected from network. If I try to reconnect, it says incorrect password even the correct password was saved before on that device. After rebooting the Orbi, the problem is solved temporarily. The same thing will happen after sometime.
- FURRYe38Aug 30, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
