Klinger123
Apr 21, 2022Aspirant
My RBR750/RBS750 is having it's internet connection start and stop over and over
I am using an RBR750 router connected to three RBS750 satellites. I live in a home with chicken wire / plaster walls so signal doesn't travel well, which is why we have so many satellites. It's wor...
- May 05, 2022
Just got off the phone with Netgear tech support and wanted to share what I learned in case any future people have this issue. They suggested one thing new and it actually appears to be working: use a hard wired connection for each of my satellites. Now I get that some people won't have this as an option but I actually do.
Recapping previous learnings, my system worked fine with just the router. It worked fine with the router and any one of the three satellites. But once I added the second or third satellite, it stopped working. So I tried adding the second and third satellites as wired and they worked. Now I'm going to try and add the first satellite back as wired and see if it remains stable.
Apr 29, 2022Guru - Experienced User
Yes, select the SSID that belongs to your system, Look at the channels there. Whats listed there. Be sure to edit out MAC addresses if you post.
This list will tell you what exact channel the Orbi is using.
Klinger123
Apr 29, 2022Aspirant
So it does show the correct channel value when I go to that screen.
What else can I do? The only thing that worked (I think?) was literally just the router by itself. What else is there to try? I am very appreciative of your help but so very frustrated at all of this too.
- Klinger123Apr 29, 2022Aspirant
I should probably add that we did upgrade from 500 Mbps to 1000 Mbps service around the same time this happened, but since the wired internet has had no problems, I figured that couldn't possibly be the issue.
- FURRYe38Apr 29, 2022Guru - Experienced User
So the RBR runs ok however when you had a RBS things start failing?
I guess run the RBR alone for a while and see how things go...
- Klinger123May 02, 2022Aspirant
UPDATE
Running the router and one satellite seems to be stable. I'm not sure why running two satellites worked fine for almost two years and running three satellites worked fine for another six months... now it doesn't.
We're tried factory resetting everything. I get that too many satellites could become problematic, but it USED to work and I can't understand why it would just stop. Are there any other things to try? Could it be faulty hardware?
I guess I could live with what I have, but it's sad to have about $500 in hardware just sitting around that I wish I could use.
- FURRYe38May 03, 2022Guru - Experienced User
Kind of hard to tell. Possible environment could be a cause. Building materials. Possible the system was working ok however may have been on the fence and with a new FW update may have push something over. Possible faulty HW or a slow degradation over time. Something you can contact NG support about and see what options you may have.
- Klinger123May 05, 2022Aspirant
- FURRYe38May 05, 2022Guru - Experienced User
Hi, thanks for the update. Ya, I don't presume that all users will have ethernet infrastructure abilities. Good idea though as a test.
No mention from NG about it had been all working until v4 FW came out?
Any mention of collection debug logs to help identify what happens when the 3rd RBS is connected?
They were about to elevate me to the Tier 2 people and possibly replace my router, but they had me try this first. I did not realize it was an option as I thought both ports were to output signal and did not realize they could connect directly to the ethernet. I probably would not have gotten a third satellite if I realized that.
They did mention potentially rolling back my firmware but they didn't even ask if I had upgraded it to the latest firmware. No mentioning about any debug logs at all.
Ok.
Well I guess this would be a good alternative for use of a 3rd RBS. However again size of home and building materials should be applied as well when considering another RBS and placement and distances.
Ya, Ethernet connected RBS is most definitely supported:
I prefer this over wireless...
Hoping this will help so you can keep the 3rd RBS running. You might want to turn down the power to 50% if you return to 3 RBS. Even in my home, I normally use 50%. Still have great coverage and all gets connected. Also help in getting some devices to connect to the RBS vs RBR.
- Klinger123May 09, 2022Aspirant
I'm going to close this out post out and say that while I did not figure out WHY the satellites stopped talking to each other, at least I have everything working now that all satellites are hard wired. I wish I knew that was an option or I would have not bought the third satellite! My mistake.
FURRYe38, you rock and your efforts to help people with no expectations in return are much appreciate. Thank you.
- FURRYe38May 09, 2022Guru - Experienced User
Glad it's working though. Be sure to save off a back up config to file for safe keeping.
Enjoy. 😉
