JGJG
Jul 08, 2022Tutor
My RBS750 won't sync with my RBR750
Okay. Forgive me for my horrible English. My router/satelitte acted last night. So I thought a firewire update will try to fix it. Router was on v3 (could not update it via website or app.) But ...
Jul 09, 2022Guru - Experienced User
You're quite a ways behind on firmware.
https://www.netgear.com/support/product/rbk752.aspx
Yes, try hardwiring the satellite into the router for getting it setup, updated, and sync'd. Once you have that done, you can disconnect it and put it back where you want it.
JGJG
Jul 09, 2022Tutor
Which FireWire would you recommend for RBR.
I tried to hook Ethernet cable to RBR and rbs. Reboot rBs and wait two minutes for it to finish start up. I see blue light. (Same as before.) Then I press both sync button on them. Rbs light blinked for 45 second to 1 minutes. Then it disappears again. I'm frustrated. It happens to my another rbs (the one I did not Manuel install FireWire in first place.)
I don't know how to access rbs via Ethernet.
- plemansJul 09, 2022Guru - Experienced User
If the satellite is blue, it means the connection is good.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
log in through the browser (not the app) and update the firmware from there. Plus you'll be able to see attached devices/satellites from there.
- JGJGJul 09, 2022TutorLogin in the orbilogin, I click attached device. It shows no Satellites.
For updating fireware, I goes to administration, fireware update. And the status says update failed when I press check button.- JGJGJul 09, 2022Tutor
Okay. I make another discovery in this weird problem of mine. I decide to see if my satellite has signal or could access internet through it only. I turn my wifi off and hook it to ethernal to my satellite. And it seems that I do have internet. But it does not still show up in my attached device.
