JGJG
Jul 08, 2022Tutor
My RBS750 won't sync with my RBR750
Okay. Forgive me for my horrible English. My router/satelitte acted last night. So I thought a firewire update will try to fix it. Router was on v3 (could not update it via website or app.) But ...
Jul 11, 2022Guru - Experienced User
try going to 192.168.1.250
that used to be the satellites default ip address
JGJG
Jul 12, 2022Tutor
Good news!
I gave the satellite another factory reset but I try for 20 seconds. It won't sync up but it finally showed up on attached device. So I got excited. It was disconnected so I decided to wire it up and reboot the router. Finally, it gave me ip address so I access it.
Now what?!
Now what?!
- plemansJul 13, 2022Guru - Experienced User
Now that you can access it, make sure the satellite/satellites are on the latest firmware (you were a ways behind). Once they're updated, then update the router.
- JGJGJul 13, 2022TutorI could not access it again. It said disconnect. But I know my satellite were on current one.
I just think the problem is the router itself. I tried to manually update it to current firmware but it failed. I did power cycles it. Still failure.
I'm getting very frustrated with them. - plemansJul 14, 2022Guru - Experienced Userdid you factory reset your router?
- JGJGJul 14, 2022TutorYes. Like a day after I made this thread as last resort.
- SeaRefractorJul 16, 2022Apprentice
What's the current firmware version on your RBR? I recall you listing a much earlier version, but I'd not seen any indication you had updated it.
What I would suggest is that you ensure all the satellites are up to date. Realize post-update they'll likely not connect as the RBR is so out of date. Next update the RBR last.
Finally factory default all of them and run through setup again. Most likely the configurations are way out of date as well.
