nitehawk747
May 05, 2023Tutor
My satellite has a poor connection to the RBR850 router
I just noticed on my computer's Netgear interface that my satellite has a poor connection. So I checked the android Orbi app to see if I could find the problem. The Orbi showed I have a 5GHz connecti...
- May 08, 2023
I moved the satellite in the room with the router to monitor both the router And satellite. While plugging and unplugging I noticed that the plug on the satellite wasn't setting the connector like it should. So I used another plug on the satellite . Now it shows a good connection and it's wired. I thought it would show better than a "good" connection, being wired straight from the router. Anyway looks like my problem was the connector in the satellite. I did look at the ethernet continuity tester. Mine does look like one of the 2-piece $30.00 tester, and the real tester was at $1600.00. Just wanted to think everybody for their help
CrimpOn
May 05, 2023Guru - Experienced User
Do I understand correctly that the Orbi administrative web site (http://orbilogin.net ) Attached Devices page showed the satellite status as "5GHz Poor"? The Orbi app simply presents the router information in a more colorful, more "modern" format. The information should be the same.
If this is the case, then the link between router and satellite is almost certainly over WiFi, and not a great connection.
nitehawk747 wrote:
Disconnect the cable press reset on the satellite, reconnect the cable, press sync on the router, then sync on the satellite.
There is no process to enable wired backhaul. The router and satellite check periodically to see if a wired connection exists and will switch automatically when one is found. Likewise, when that check discovers that the wired link is not there, they will switch back to WiFi backhaul. The user has no control over this activity.
In general, people on the forum recommend this practice regarding wired backhaul:
- With the satellite in the same room as the router, power up the satellite and sync it with the router.
- Observe that it indeed does sync. (Blue light. Attached Devices shows a good connection. - which may take several minutes to appear).
- Connect a router LAN port to a satellite LAN port with an Ethernet cable.
- Observe that after a period of time, Attached Devices shows that the connection is now 'wired'.
(The frequency of checking for a wired link is not documented and I have not sat and done it enough times to form an estimate of how fast it happens.) - Relocate the satellite to the desired location. Connect it to Ethernet. Power it up.
If the satellite showed 'wired' when connected directly in the same room, but never switches to a wired backhaul in the desired location, there is almost certainly something wrong with the cable path.
- A kink, stretch, or break in the cable itself.
- One or more RJ45 connecters crimped incorrectly.
- One or the other Ethernet patch cables not perfect.
