bsohne
Apr 20, 2021Aspirant
My WIFI network became "open" after adding a 3rd satilite
Hello everyone I have a RBR750 V3.2.18.1_1.4.14 with two Sats , I added a thried all went well.. when the system came back up .... The wifi access near the router and one of the original sat...
bsohne
Hi
Sorry was not clearer...
I have the two sat system up and running for 6 months... no issues...
I went thru Ios app to add a 3rd sat this am. going thru hitting sync etc... all good...
after rest .. the network on 2nd floor still required pwd to connect...
Network on thrid floor has the WFI network "OPEN" no password ... even after to reboots and the second one with the new thrid sat removed.
Not sure why... I guess I will have to after hours go thru the UI to remove the third sat , reboot and see if i still have issue... if i do i guess i need to remove all sat and re add all and see if that clears it up...
any advise?
thanks
bill
Apr 20, 2021Guru - Experienced User
Reset the 3rd RBS then try syncing with the back button on the RBR and RBS. Have the RBS in the same room as the RBR. Turn OFF other RBS in mean time.
Do you have any special characters in your SSID Password field?
bsohne wrote:Hi
any advise?
thanks
bill
