Camdiggy
Aug 27, 2021Follower
My Wired connection to an Orbi Satellite is slower then my Wireless to the same Satellite
I have xfinity 1 Gb service to the house and a xfinity xfi modem in bridge mode. The xfi model is connected through a CAT7 eithernet cable to an Orbi RBK843 Router. The Orbi Router is about 45 ft f...
Aug 28, 2021Guru - Experienced User
Be sure the drivers for the adapter are up to date.
Disable any QoS settings on th ethernet adapter. I believe some Killer adapters have this featuers.
Please try the PC while connected to the RBR.
Try a differnent PC or ethernet adapter connected to the RBS.
