zahmnd
Jun 05, 2022Tutor
Mynetgear account password recovery is broken.
Placed into Orbi because I just bought an Orbi system (and am regretting it now since the website does not work - bad first impression) and there's no category that I see for website support. Iss...
- Jun 06, 2022
Hello zahmnd ,
This issue should now be resolved. Can you please confirm if you're able to reset your password now?
Kind Regards,
Christine
Jun 05, 2022Guru - Experienced User
Try using Forget PW here:
https://store.netgear.com/loginshow?returnUrl=https%3A%2F%2Fwww.netgear.com%2Fsupport%2Fdefault.aspx
Select the Forgot Password option.
This is for the NG account profile.
What Orbi model do you have?
- zahmndJun 05, 2022Tutor
Thanks, but that won't help since the broken password recovery site that I linked is the redirect from https://store.netgear.com/loginshow?returnUrl=https%3A%2F%2Fwww.netgear.com%2Fsupport%2Fdefault.aspx
I need to access https://my.netgear.com/ - but I can't because I don't recall my password and the password recovery is broken. The Orbi model that I just purchased is an RBK753.
Note that password recovery is also broken within the Orbi android app, since the Reset Password API response is an HTTP 500/internal server error
- FURRYe38Jun 05, 2022Guru - Experienced User
I would reach out to a forum moderator and have them help you on this. This will need there help as this is beyond forum help.
thank you FURRYe38, I will do so. I thought I'd raise the issue for visibility since it's centralized in nature, and since there was no way (at least that I could see) to engage website support.
