zahmnd
Jun 05, 2022Tutor
Mynetgear account password recovery is broken.
Placed into Orbi because I just bought an Orbi system (and am regretting it now since the website does not work - bad first impression) and there's no category that I see for website support. Iss...
- Jun 06, 2022
Hello zahmnd ,
This issue should now be resolved. Can you please confirm if you're able to reset your password now?
Kind Regards,
Christine
Jun 05, 2022Guru - Experienced User
Try using Forget PW here:
https://store.netgear.com/loginshow?returnUrl=https%3A%2F%2Fwww.netgear.com%2Fsupport%2Fdefault.aspx
Select the Forgot Password option.
This is for the NG account profile.
What Orbi model do you have?
zahmnd
Jun 05, 2022Tutor
Thanks, but that won't help since the broken password recovery site that I linked is the redirect from https://store.netgear.com/loginshow?returnUrl=https%3A%2F%2Fwww.netgear.com%2Fsupport%2Fdefault.aspx
I need to access https://my.netgear.com/ - but I can't because I don't recall my password and the password recovery is broken. The Orbi model that I just purchased is an RBK753.
- zahmndJun 05, 2022Tutor
Note that password recovery is also broken within the Orbi android app, since the Reset Password API response is an HTTP 500/internal server error
- FURRYe38Jun 05, 2022Guru - Experienced User
I would reach out to a forum moderator and have them help you on this. This will need there help as this is beyond forum help.
thank you FURRYe38, I will do so. I thought I'd raise the issue for visibility since it's centralized in nature, and since there was no way (at least that I could see) to engage website support.
- CrimpOnJun 05, 2022Guru - Experienced User
Please excuse my confusion. Are the account credentials for mynetgear the same as the credentials for the community forum?
They are. I registered a secondary account so that I could log onto these forums.
