zahmnd
Jun 05, 2022Tutor
Mynetgear account password recovery is broken.
Placed into Orbi because I just bought an Orbi system (and am regretting it now since the website does not work - bad first impression) and there's no category that I see for website support. Iss...
- Jun 06, 2022
Hello zahmnd ,
This issue should now be resolved. Can you please confirm if you're able to reset your password now?
Kind Regards,
Christine
ChristineT
Jun 06, 2022NETGEAR Employee Retired
Hello zahmnd ,
Kind Regards,
Christine
zahmnd
Jun 06, 2022Tutor
Yes! Working now. Thank you very much.
- FURRYe38Jun 06, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
