larutan
Dec 07, 2021Follower
MyQ 2.4G Garage to Orbi RBR750 (non-technical)
Like many folks I was having difficulty getting the MyQ garage door opener set up after upgrading to Orbi AX4200. I understood that the problem was my phone was connecting via 5G to the network inst...
Dec 08, 2021Guru - Experienced User
Also try turning down the power output of the RBRs wifi radios from 100% to 25% Under Advanced Tab/Advanced Settings/Wireless Settings as well to help with the distance vs connection with the mobile device.
Enjoy.
