gb777
Jul 18, 2020Apprentice
NAT loopback debugging help wanted
As you all know the RBR 75x and RBR 85x series do not properly support NAT loopback. The question is how did they manage to screw this up? Here's what I've found so far. - they have set up the ...
gb777
Jul 29, 2020Apprentice
So I found out the NAT loopback works if the connection from the router to the server being accessed is via one of the ethernet ports on the device (rather than through an intermediate switch). I also found out that this is likely due to the
bridge-nf-call-iptables
setting, based on information in a forum of a different consumer device.
That is, if you issue:
echo 0 > /proc/sys/net/bridge/bridge-nf-call-iptables
it will work (just as if you turn on promisc mode on br-lan).
So this is interesting. The RBR 750 uses Linux's virtual bridging (a software implementation of Layer 2 switching) to connect the 3 physical ethernet ports (eth1, eth2, eth3) and the wireless interfaces into a single bridge interface. The problem is not the type or kind of switch, it's the fact that those packets cannot be sent directly to their layer-2 receiver. I don't fully understand it yet.
orbira
Sep 04, 2020Apprentice
How do you login to the router? I have not been able to enable telent on that. Any pointers for that? I can then probably star looking at the pitiable rules.
Thanks
