jacoblee16
May 23, 2022Aspirant
NAT Moderate/UPnP not successful XBOX ONE
Product: ORBI AXE11000 RBKE963B Firmware Version V6.0.3.85_3.1.15 Problem: NAT type moderate/ UPnP is not successful. I attempted to cut off/on UPnP, device, and router. I tried clearing cache o...
- May 24, 2022
Again press the front power button on the box and let it shut off. Then release.
Go in to the RBRs web page and change the NAT Filter to OPEN under Advanced Tab/WAN setup. Apply and reboot the RBR.
After it's ready, turn ON the xbox. Check NAT status.
jacoblee16
May 24, 2022Aspirant
Is Armor or SPC enabled on the RBR? No
Is the xbox wired to the RBR or wireless connected? The Xbox is wired to router
Has a factory reset and setup from scratch been performed on the RBR then setup with out any additional features. Hold the front power button on the xbox until it shut off then back ON then check NAT settings? Yes, I have hard reset and held the power button down - still Moderate NAT at this time.
May 24, 2022Guru - Experienced User
- jacoblee16May 24, 2022Aspirant
Nat filtering to Open worked.
To get here I navigated to http://orbilogin.net
Sign in, Advanced Tab, Setup, WAN setup, NAT Filtering Open
However, from my research, this is less secure?
- FURRYe38May 26, 2022Guru - Experienced User
I now have my RBRE960 online with a CM2000 cable modem.
NAT Filter here is set for Secure.
Both of my XB1s show OPEN NAT on there Dashboards.
