jacoblee16's avatar
jacoblee16
NAT Moderate/UPnP not successful XBOX ONE
Product: ORBI AXE11000 RBKE963B Firmware Version V6.0.3.85_3.1.15   Problem: NAT type moderate/ UPnP is not successful. I attempted to cut off/on UPnP, device, and router. I tried clearing cache o...
  • FURRYe38's avatar
    Again press the front power button on the box and let it shut off. Then release.
    Go in to the RBRs web page and change the NAT Filter to OPEN under Advanced Tab/WAN setup. Apply and reboot the RBR.
    After it's ready, turn ON the xbox. Check NAT status.
