Ajujdeorbiuser
Nov 03, 2024Aspirant
NAT settings on RBR750
Hello Experts, Please help me to setup my RBR 750 router NAT to open. My PS5 and Nintendo switch connection shows moderate. Router is connected to gateway. From gateway end the NAT is open. Confirmed...
Nov 03, 2024Guru - Experienced User
If you have a router/ gateway at the ISP modem or ONT and you put the RBR in router mode connected to the gateway, then this will be double NAT condition.
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Most you'll ever see from Sony PS is NAT type 2 behind a gateway ISP router system. Type 1 can be achieved if connected to a ISP modem or ONT with out any built in router.
