jEfFrEySb's avatar
jEfFrEySb
Follower
Feb 27, 2025
navigation to change channels rbr 760
On windows 11 I can only navigate with the tab button making doing anything impossible.  I've tried wireless and bluetooth.  I can only use the tab key and no other key.
I've tried other computers and it's the same thing.  I can't figure out what the problem is although I'm sure the solution is simple.
Any help would be appreciated.
1 Reply
  • CrimpOn's avatar
    CrimpOn
    What connection does how a Windows 11 computer works (or fails to work) have with a Netgear Orbi 760 router?
    Does the Windows 11 computer function correctly when doing "everything else" but somehow fails when attempting to access the Orbi web interface? (using what web browser?)
