HaJoS's avatar
HaJoS
NBN issue with latest firmware versions
I use a RBR750 with 2 satellites and they were just running perfectly. I am connected to NBN and I never needed to reboot and the connection to the internet was stable and great.   Later came firmw...
  • HaJoS's avatar
    HaJoS
    Sep 03, 2024
    It has been pointed out from the logs that there are many DHCP requests from several sources followed by a disconnect event. Thank you for this!
    I now have assigned most of my devices a reserved IP address and have also enabled IPv6 on the ORBI.
    Then I updated the firmware to the latest version 7.2.6.31 which never worked longer than 1 day. For the FW upgrade, I used this time the ORBI app on my phone.
    Since then, no more crashes, everything runs very smoothly.
    I will further monitor it, but it seems to me these frequent DHCP requests have caused the system to crash. Strange though, a DHCP request should be a very basic function...
