cjscotty32
Aug 09, 2022Aspirant
Need Advice on extending Orbi Wifi
Hi... I have an Orbi RBR850 with 4 RBS850 in my home, but I need to extend to my shed, but the current wifi signal does not reach although one of the Orbi's is placed as close to the shed as possible...
CrimpOn
Aug 09, 2022Guru - Experienced User
Yes, another RBS850 can connect over an Ethernet cable.
cjscotty32
I thought all the ports on the Satellite were for output...how do you configure it for input?
- CrimpOnAug 09, 2022Guru - Experienced User
No configuration is required:
