Scselig1's avatar
Scselig1
Need dire help with Orbi ax4200
I have a Orbi ax4200 router plugged into nighthawk cm1200 modem. I had 3 satellites also connected. All satellites are now gone from my app. I have tried to factory re set the satellites and even tried direct Ethernet one into router and still cannot be found. Can someone please help? This was a picture before I factory re set.
  • It is literally hooked in via Ethernet chord and the router doesn’t recognize it as a satellite. It thinks it’s a device.
  • FURRYe38's avatar
    What does the RBRs web page display for the RBS?
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    Are RBS all wirelessly connected to the RBR or ethernet connected to the back of the RBR?
