Rob02Aggie
Dec 01, 2020Aspirant
Need help getting Orbi on Same subnet as my wired devices
I recently replaced two secondary wifi routers with the RBK853 system which consists of an RBR850 and two RBS850 satellites. The first problem I ran into is that the wireless devices can't see my wi...
Dec 01, 2020Guru - Experienced User
running 2 routers in router mode does tend to create issues.
Its called a double nat
https://kb.netgear.com/30186/What-is-Double-NAT
options?
1. disable the router on the att device and put it in passthrough/modem only. I'd contact att if you wanted to do this.
2. Put the netgears IP address in the att devices dmz.
3. put the netgear in AP (access point) mode. It disables a few features but leaves the ATT router controlling the system. You still have wifi ethernet on the Orbi. This tends to be the easiest router but again, you loose a few features.
- Rob02AggieDec 30, 2020Aspirant
Thanks for your reply. I'm not sure how to do some of those things. I would require more detailed instructions.
for #1, I still have some wired devices on the AT&T devices, if I disable the router on the AT&T device will those still get connectivity?
I don't know how to do #2.
What features would I be losing in step 3?
- plemansDec 30, 2020Guru - Experienced User
If you disable routing functions on the att device, the only thing you can connect to it is the orbi.
in terms of the disabled features:
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
