b1onny
Sep 30, 2023Follower
Need help, Rbr350 won’t connect to plw1000 via Ethernet
So I was using an asus router for ages with the PLW1000 hooked up, all running well, then when I switched to the rbr350 router it for some reason won’t pick up the Ethernet, everything plugged in per...
CrimpOn
Sep 30, 2023Guru - Experienced User
Is it correct to assume that the PLW1000 (pair of PowerLine adapters) is used to connect the router to the Internet Service Provider (ISP) modem/ONT which is in a different location?
Was the ISP modem powered off and back on?
