Skipwoodham
Jul 20, 2022Aspirant
Need recommendations for best wireless camera to use with Orbi 6 mesh with 2 satellites
Looking to put at least 3 cameras on the system. TIA
CrimpOn
Jul 20, 2022Guru - Experienced User
Every major brand of camera will work with the Orbi WiFi network. The decision should be based on which "ecosystem" you prefer.
- Are you a Google Nest person?
- A Netgear Arlo person?
- A TP-Link, Wyze, etc. etc etc.?
Skipwoodham
Jul 21, 2022Aspirant
Not really a technical guy….just need a couple of cameras that work well and have motion detection. What brand would you recommend for ease of installation and set up. Need one outside and one inside. And do they have to be the same brand to work seamlessly on the Orbi?
TIA
