DBC55438
Jun 25, 2022Aspirant
Need some help with double NAT config
- I have CenturyLink Gig Fiber connected with a Calix C844G - Wireless radios are off, and inside the Calix NAT, IP is at 192.168.0.1 - Ethernet connects to my Netgear CBRE960 at 192.168.0.2 - Ins...
- Jun 26, 2022
DBC55438 wrote:
Question, is how do I configure the Netgear Port Forward and the Calix Port Foward jointly so Tablo can get through the Double NAT?
The solution depends on the capabilities of the Calix device.
- If the Calix supports Port Forwarding, then simply:
- On the Calix, forward those two ports to the Orbi IP (192.168.0.2) with the same port numbers (21145 and 21144)
- On the Orbi, forward those two ports to the TVs IP as instructed (21145 to 8887 and 21144 to 80) . (Port forwarding must have a destination IP.)
- I have done this through three routers.
- To avoid having to go through this process over and over again with other applications, the most common advice would be to turn one of the routers into "not a router", i.e.
- Put the Calix into "bridge" or "modem only" mode. This allows the Orbi to be the only router, so ports have to be forwarded only once.
- Put the Orbi into Access Point (AP) mode. This turns off all of the router functions, including DHCP serving, Armor, Parental Controls, port forwarding, VPN, etc. Then the Port Forwarding must be done on the Calix.
- If the Calix does not support Port Forwarding but does support DMZ, then you could try putting the Orbi's IP into the Calix DMZ.
I am not confident that putting the Tablo in the Orbi's DMZ will work because of the need to change port numbers.
michaelkenward
Jun 26, 2022Guru - Experienced User
What's that?
Netgear's support system denies all knowledge of any CBRE960.
Do you mean RBKE963? Or some other Orbi?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
If that is what you own, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi WiFi 6 (AX) and WiFi 6E (AXE) - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
