tahaasha
Mar 07, 2021Follower
Need to connect One Orbi RBK85 router with 5 Orbi RBS85 satellites using LAN cable and switch
The model I purchased is not found in the list, so I:m adding the details here Orbi RBS850 count 5 Orbi RBR850 count 1 Windows 10 Ver 2.8.5.15 I want to connect 5 satellites and 1 router to a s...
Mar 08, 2021Guru - Experienced User
You'd probably find the model (and better helps) on the orbi AX forums.
Home Networking - NETGEAR Communities
But that model does support a wired backhaul.
What is Ethernet backhaul and how do I set it up on my Orbi WiFi System? | Answer | NETGEAR Support
