kildren's avatar
kildren
Need to Disable BackHaul on one RBR850
I've got 2 Routers, 3 Satellites, I have over 150 Wireless Devices, and another 90 wired devices, so tried to set one RBR850 up as a AP, keep the other one as a Router with the 3 Satellites, And moved 90 wireless devices over to the RBR set as a AP.  Backhaul is really screwing me up, the AP RBR shows as a Satellite, and my other 3 satellites are swapping between the 2 RBRs.
I've moved DHCP to a Server, and am using a 255.255.254.0 subnet mask.
I need to somehow disable the Backhaul on the AP Router.  Its causing Major disruptions on my Network.
  • Should say too, when I had all the devices on the one Router, I get random wireless Drop outs on devices hence why I was splitting them when I read somewhere the RBR850 can only handle around 120 Wireless Devices, had a spare RBR from a sail with a satellite that was cheaper then buying a satellite so tried to use it.
  • plemans's avatar
    I ran into the same issue with my RBE970/971 when I tried to use a 2nd router as an AP. You used to be able to do it, not anymore. It caused way to many issues. Could be the firmware change trickled down to the RBK850 series.
  • CrimpOn's avatar
    CrimpOn
    It would be really helpful to know more about
    • how these Orbi units are connected to each other.
      • The RBR850 that is in AP mode is 'wired' to something using its WAN port.  What is it wired to?
      • How are the satellites connected? ('wired' or using the default WiFi?)
    • The WiFi SSID being used by these two routers is
      • The same SSID? or
      • Different SSIDs?
    It is physically impossible to "disable" the WiFi backhaul of an Orbi router.  That feature is what makes it an Orbi WiFi router.  (Well, you could open the case and cut the wires to the four backhaul antennas, but really???)
    When RBS850 satellites are paired to an RBR850 router, they do not "swap" to other routers.  The backhaul channels have different SSIDs/passwords.  Just can't happen.
    • kildren's avatar
      kildren
      Well I can say it is, it shows up as out of sync on the AP Router, and the AP ROuter is showing up as a Satellite in the Main Router...
      • FURRYe38's avatar
        How is the RBR connected to the host router? WAN port of the RBR the host router or ISP router? Should be using the RBRs WAN port to connect to the up stream routers LAN port.
        How is the RBS connected to the RBR? Wireless or ethernet?
