norbertsf
Dec 09, 2022Aspirant
Need to keep restarting RBRE9606E (AXE) router to get fast Wifi- problem resurfaces AGAIN
Resurface of previous issue. Tried factory reset and that only helped for a week or so... I have a RBRE9606E (AXE), with 2 satellites. Firmware V6.3.7.5_3.2.25 ( I know there is a new FW out. th...
Dec 09, 2022Guru - Experienced User
What problem are you seeing?
I see from your last post thread that you didn't give feedback to some questions presented, lets see if we can get some here huh?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
For that size of home, the RBR would only be needed. If you have one RBS deployed, I recommend reducing the power to 25% Under Advanced Tab/Advanced Settings/Wireless Settings
Try setting channel 1 and 40.
Recommend setting the default DHCP IP address pool range to the following: 192.168.#.100 to 192.168.#.200
- norbertsfDec 09, 2022Aspirant
Hi, Thank you for the help.
Comcast modem is: xFi advanced gateway, Model XB7 CGM4331COM
I have a CAT 6, 550Mhz verified cable betweenModem and Orbing router.
I made your suggested changes:
2.4Ghz set to 1
5Ghz set to 40
LAN set-up set to:
192.168.1.100 to 192.168.1.200
Advanced Wireless settings for 5Ghz and 2.4 Ghz reduced to 25%
For reference I am getting 489 Mbps down, after this change, which is what I always get after a restart of the orbing Router.
Will see if that changes anything?
- FURRYe38Dec 09, 2022Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first...
Modem is and has always been in bridge mode.
