moonwatcher64
Aug 22, 2022Luminary
Need to label my Satellites (RBR850) but cannot see an obvious way to do that -Advice Very Welcome
Evening all. Have a 4 sat system. Works nicely in the main but I cannot identify each Sat. I made the mistake of leaving them as standard naming. Is there an easy way to identify each one such th...
- Aug 22, 2022
moonwatcher64 wrote:
đI did try switching each sat off and thinking it might go red in the network map but strangely it did not.
That should work. It will not happen instantly. It may take 10 minutes (or more) for the status display to change.
Aug 22, 2022Guru - Experienced User
You can change the name of the RBS on the RBRs web page as well. I use this to have info on where about my RBS are located.
moonwatcher64
Aug 23, 2022Luminary
Thanks for the suggestion but I'm trying to identify where each sat is ... physical location, so that I can label up in the way you mention.
I can see how to change the label but first I have to have a method to identify the Orbi Sat.
In other similar product systems where you have a number of devices, all appearing very similar, you have tap a key or such like and the on-board LED will flash maybe 3 times in a distinct colour.
Once I can identify the specific sat, then I can label each and be better organised for future.
