moonwatcher64
Aug 22, 2022Luminary
Need to label my Satellites (RBR850) but cannot see an obvious way to do that -Advice Very Welcome
Evening all. Have a 4 sat system. Works nicely in the main but I cannot identify each Sat. I made the mistake of leaving them as standard naming. Is there an easy way to identify each one such th...
- Aug 22, 2022
moonwatcher64 wrote:
đI did try switching each sat off and thinking it might go red in the network map but strangely it did not.
That should work. It will not happen instantly. It may take 10 minutes (or more) for the status display to change.
CrimpOn
Aug 22, 2022Guru - Experienced User
moonwatcher64
Aug 23, 2022Luminary
Thanks CrimpOn. I will try that again.
