Ddddggdg
Feb 12, 2025Tutor
Need to reboot after a power outage - Satellites sometimes don't connect and display hidden SSID's.
Hi, I have an RBRE960 and two RBSE960 Satellites, with Satellites connected via ethernet backhaul to the RBRE. They are running V7.2.6.31 and for the most part are running well and stable, however ...
Ddddggdg
Feb 26, 2025Tutor
thanks for the reply, the RBS's are connected direct and not through a lan switch. There are lan switches in my network but not in between the RBR and RBS's. I just seen a new firmware come out, I will wait and try that rather then downgrading and test out a simulated power outage. will provide feedback from that.
Feb 26, 2025Guru - Experienced User
I recommend after updating FW, RBS first, the RBR lastly, factory reset and setup from scratch.
